Problem with Edius 5.11
  • Problem with Edius 5.11
    Hello i have the edius 5.11 update and i have this problem,when i edit it stop,to play,to change from clip to clip,when i put a song to timeline and anyway when i use it,it stop about two or three seconds and it start again.Do anyone why?
    Thank you!!!
    Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
    Socket 1366 LGA (0x1)
    Chipset
    Graphic Interface PCI-Express
    Memory Type DDR3
    Memory Size 4096 MBytes
    Channels Single
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1
    DirectX Version 11.0
    Graphic
    Name NVIDIA GeForce 210
    Revision B1
    Codename GT218
    Technology 40 nm
    Memory size 1024 MB
    you need to update to EDIUS 5.51 (free) in order to use successfully in Win7
    do not place VBR mp3 audio clips on timeline
    use wav stereo 48k files for perfect results
      Ok thank you very much i tsek this!!!!
      Chipset
      Memory Type DDR3
      Channels Single
      Graphic
      Revision B1
      Codename GT218
      Technology 40 nm
      Memory size 1024 MB
        Please,i update to 5,51 but the problem is still there?Any other reason ?
        Chipset
        Memory Type DDR3
        Channels Single
        Graphic
        Revision B1
        Codename GT218
        Technology 40 nm
        Memory size 1024 MB
          you can check the settings... there is an option to avoid EDIUS stop playback at drop frame
          Paranova Films
          Cali - Colombia
          http://www.paranovafilms.com/
            Where are the files residing within the system. Do you have a dedicated video drive, or raid, and how full is this drive?
              also, provide project settings and the type of clips used on video and audio tracks
              also, confirm that not antivirus software or windows defender is running
              and check to see if Win7 is set for performance and not childish fade in and out and animate menu effects
              Windows 7 64bit optimization settings for Grass Valley Edius users by disabling services and windows features that may otherwise slow the workflow
                look i have two external disks,one for the editing and the other for the externals files,the video clips are dv format from dec tapes in the first disc for the edit.I transfer all the project from disc to another and also to the main disc(c) but the problem is still there.Someone anything?
                Chipset
                Memory Type DDR3
                Channels Single
                Graphic
                Revision B1
                Codename GT218
                Technology 40 nm
                Memory size 1024 MB
                  could you provide answers to my previous questions? this is important in order to diagnose the cause
                    In order for us to help you the information that was asked for is required.
                    How can we diagnose a problem without all of the information.
