WMF and audio sync
  • WMF and audio sync
    We are doing a series of training video. They are shot in AVC-Intra 100 and run between 20 and 45 min.
    All the clips play fine on the timeline in Edius 6.07, but when we make a review WMF for the client the audio is off by a couple of frames. There are no filters on the audio. Any suggestion?
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
    tdtinker
    Is it out of sync at your end or the client? Maybe try out another codec, just to see if the same is happening, at least this will help to identify any potential problems.
      also
      make sure the settings in wmv exporter are both on CBR for video and audio, and not CBR for video and VBR for audio etc
        Both, If we play it a couple of times the sync comes back in line, I'm going to check what Anton said. I don't remember by 1st setting. Will give you an update shortly.
        PS Anton why are you up so late?
        tdtinker
        Edius 8.5
        www.actvp.com
          it is not late, it is only 00:10
            It looks like we used CBR for both. We're making another file this morning.
            tdtinker
            tdtinker
            Edius 8.5
            www.actvp.com
              Personally, I don't use windows media at all. In the past I had a number of issues with playing full screen and high frame sizes and bitrates etc. I think most of my issues may have been to do with VC1.
              You may want to try a test using H264/MP4, at least to see if this has the same issues. If not you may want to start using that format, it is more universal than windows media. I know this could be an issue with your client, but if you can guarantee something more solid it may swing it for you. You may want try the VLC player, it's free, and completely self contained with its own playback codecs.
              If you find this route a good one, you may also want to try out another workflow for producing low bandwidth high quality H264/MP4. X264 is brilliant, I use MeGui, although Handbrake is quicker and easier. Just encode your timeline to YUV and then feed it to Handbrake, there has been a new version in the last couple of months and it may now see HQ and HQX. Using this method, you can even change the extension to FLV and stream it via flash.
              Here are a couple of links that have media that has one way or another been through X264 and altered either to MP4 or FLV and authored via the standard flv plug in Dreamweaver.
              http://www.davidharry.com/paulharcomb/index.html
              http://www.davidharry.com/video_show...ase_index.html
                I should have added that these file are just for review and approval, the final product will be a DVD. When they see a voice out sync they are less likly to sign off. Even when we tell them that is just WMF.
                tdtinker
                tdtinker
                Edius 8.5
                www.actvp.com
                  tdtinker
                  In that case H264 may be a better solution all round. You can do a quick HTML page from a pre-set and stream across multiple platforms. It would be only slightly longer than posting to a URL/FTP or shared space, if that's how you get it to your client, and way faster than posting. I do it on nearly everything that I work on, it's quicker and cheaper than anything else for remote viewing and the clients usually get a buzz out of it.
                    tdtinker
                    was there any izotope applied? this will create a 2 frame audio delay
                    I actually make the wmv in TmpgEnc mastering Works5 from Canopus HQ Fine file, it makes way sharper wmv (mindblowing actually) than EDIUS wmv exporter
                      No izotope.
                      tdtinker
                      Edius 8.5
                      www.actvp.com
                        what about the quality slider, was that at 100%
                        and what was the frame size and video/audio bitrate?
