Audio Normalization Issues
  • #31
    is the clip butted up to another clip? the normalize tool searches a window range of 300ms by default which is around 6 frames, so it could pick up info from adjoining clips if it is the same file just cut up
    in user settings duration, automatic correction, you can change it to a shorter time and see if that works better
    40ms = 1 frame
    let me know if a shorter time works better
    The shortest I could make it was 100 and that made it worse. It made the clip quieter. I had tried this with the clip in its own sequence with nothing around it and had the same effect.
    • #32
      ok, it was worth a try
      what I do is normalize a clip so that it peaks at -6 on the audio mixer VU (I always have audio mixer open)
      I then increase track height so I can see the waveform well, then I normalize the clip next to it and see if waveform height matches, if not, I click normalize again and change the value by rolling the mouse wheel
      I do this in my sleep now and already know what value to use if a waveform looks slightly lower or taller, I usually get it right with the first correction
      you can also normalize all selected clips in one hit and then correct the ones that look wrong, this is the fastest way
      for more precise and expensive jobs, I export the audio file and fix it in Soundforge
      • #33
        Nicolas. If you have a number of quieter clips that you can see or hear. Why don't you just move their audio parts to a new audio track. Then you can just increase the channel fader to bring up all the lower parts to a better level compared to the louder parts. Doing the reverse with the louder parts will also give you some room to balance both if the dynamic head room is quite wide. It is really quick to do this and would help you mix the piece as opposed to applying anything to individual parts. Applying anything to individual clips is much harder to trace backwards later in a mix if you need to change things, and is not really how you would do audio mixing anyway. If you learn to sub group things it gives you a lot more control in the mix and is very fast. Plus, Edius can easily do this. This method of controlling parts is a standard way of dealing with audio in traditional audio/music post and also in film and TV audio production. Altering the core of any audio source through individual dynamic processing should really be a last resort, as it it will fundamentally take it away from other associated audio, and make it harder to mix.
