exporting stills using ctl + T
  • exporting stills using ctl + T
    Trying to save all stills as jpegs and not bitmaps while exporting using ctl + T. I tried going into settings and menu from export. Any idea's?
    Thanks,
    Ara
    You can select the export file type under Settings > Plug-in Settings. Not sure why it is in this menu, but it is.
    Andrew Pinder
    www.chpv.co.uk
      Thanks. That did it. Can't beleive that slipped by me.
      Thanks,
      Ara
