Drop Shadow
  • Drop Shadow
    G'day
    How do you apply a Drop Shadow in Edius?
    I have used Layouter to do a Picture in Picture and want to put a Drop Shadow around the box picture I have created.
    Mark
    Mark Twittey
    Walkabout TV
    Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
    Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
    5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
    Apply 3D PIP from the Keyers and the Drop shadow is available under "OPTIONS"
    Once enabled it can be controlled under "LIGHT & SHADOW"
    You will have to do your PIP in 3D PIP as well for it to work so set layouter to "default"
    Regards Barry
      Thanks Barry
      Works great
      Mark
      Mark Twittey
      Walkabout TV
