At 1080 60p or 720p i notice stuttering when i play back the footage on the timeline. Evan when i burn to DVD i notice some stuttering when i watch on TV. what am i doing wrong ,can any one help me please. on 1080 60i i am fine no stuttering on p's
Help stuttering on project 1080 60p
Last edited by dhardjono; 04-27-2012, 01:31 AM.AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
850 power suply
32GB (8GBx2) DDR4/3000MHz
ASUS TUF X470-Plus Gaming AM4 ATX
EVGA GEFORCE RTX 2080 SUPER GPU
Windows 10 Pro
HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPMTags: None
What are your project settings, clip properties and your computer specs? Are you seeing this on your computer monitor or the output reference monitor?Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
What is your buffer as it plays? Does it run out?1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
Project setting is 1080 60p clip property 1080 60p pc spec is window 7 i7 3.07ghz -ram 12 gb - 64 bit. i am using the monitor from the pc don't have external monitor.AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
850 power suply
Windows 10 Pro
Originally posted by dhardjono View PostAt 1080 60p or 720p i notice stuttering when i play back the footage on the timeline. Evan when i burn to DVD i notice some stuttering when i watch on TV. what am i doing wrong ,can any one help me please. on 1080 60i i am fine no stuttering on p's
the buffer is 127 to 128AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
850 power suply
Windows 10 Pro
original file is progressiveAMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
850 power suply
Windows 10 Pro
Originally posted by David Harry View PostIt could be any number of reasons, but looking at your setup and project settings it would appear that you are doing everything right. It could be something to do with the file. Maybe upload one of your original clips that stutters. At least this way others may be able to test it on their systems. mediafire.com is a good place for free distribution of files upto 200MB in size. If the stutters are random in nature, this could point to a problem on your system. Again, this could be confirmed by others testing your files.AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
850 power suply
Windows 10 Pro
Originally posted by dhardjono View PostIt does not stutter all thru out the video mostly when i am panning this is the same with 720p. i try to encode Anton way with tmpg and it does not stutter on DVD but same with tmpg for blu ray it stuttering so now what thanks.
If it's not your system and overlay being out of sync. It could be that your shutter speed was too low on the shoot. Also sounds like project settings and clip settings not being exactly the same.
Upload one of your panning clips, I think this will help you get to the problem faster as other experienced users will be able to help. Someone else may pick up on something that you missed.
Right click on the file in the bin and convert to hq. Will the converted file play without stuttering?Jerry
Originally posted by Jerry View PostRight click on the file in the bin and convert to hq. Will the converted file play without stuttering?
It is possible that someone can set a project as 60P, due to the common misconception of the term, and in fact be importing 59.94. This would cause the same effect as is being reported, due to frame interpolation. This may well be the case. If so, a render to HQ would still show the same issues.
I think it would be best to post a clip, or there will be a lot more variables/questions/requests that will be asked. In these types of scenarios, things usually go round in circles due to the unclear nature of the issue.
Originally posted by Jerry View PostRight click on the file in the bin and convert to hq. Will the converted file play without stuttering?AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
850 power suply
Windows 10 Pro
sample footage
Originally posted by David Harry View PostAlthough this would help to identify if there is a format playback issue to do with the source codec. It does not sound like this is the case, as BD playback is also stuttering from a rendered file. Of course, there could also be an issue with the file preparation and the BD setup as well. Not knowing if the BD is 29.97 or 59.94 is also going to cause a lot of guessing.
sample footageAMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
850 power suply
Windows 10 Pro
what you are seeing is typical PC monitor overlay stutter
I am playing your clip in a loop and it looks totally smooth on external 42" Plasma connected to the EDIUS SP hardware via component
I can see the stutter on the EDIUS overlayAnton Strauss
