Hi Raven I had the same ploblem and it looks like it is when your hard drive does not capture quick enough. Try not to capture on the same drive on what your o.s is loaded
Edius Pro 3.6 / DVX-E1(W) Capture Problem
Off-Course
Originally posted by [email protected] View PostHi Raven I had the same ploblem and it looks like it is when your hard drive does not capture quick enough. Try not to capture on the same drive on what your o.s is loaded
I have posted the cause: corrupt data on the original tapes. The device used had a loose head and when it read the tapes it made minor errors. The DVX card picked them up, the built-in 1394 didnt see them and just copied the tapes with errors.
