Motherboard for NX Express??
    No it's not. Get the Quad Core and OC it to 3.0.
      I have an older Dual Xeon system and a new Dual Xeon Dual Core system
      both work the same speed in anything Edius
      Can't be because the Quad Core's are a newer architecture and they have faster bus speeds....
      A better test would be your Dual Xeon and a Quad Core with After Effects multi-core rendering enabled.
        We;re talking about EDIUS Dave.
          yes, I was comparing Edius performance on both systems
          in fact the older system performs better with all SCSI Raid0 drives than the new with all SATA Raid0
            "Compatibility Certifications may 'looks' tempting but not neccessary problem free".
            For my case, my iWill DJ800 is certified by Canopus but Hadware issues could still occurs.
            Thus, should get more Reviews from Canopus users before buying. Another lesson to be learnt !
            Sigh!
            Originally posted by jonandmarkuk View Post
            I'm looking at getting an Eduis NX Express Pci-e card and wondered if it would be compatible with the Gigabyte GA-M57SLI-S4 motherboard. I have looked on the hardware listing and it doesn't show but there is nothing obvious which would indicate I should have any problems.
            I would have thought if anything it would be down to the chipset on the board.
            • #21
              Of course. But it's better to be prepared for the future than anything else.
              I'm sure Edius will be optomized to use more than 2 cores itself, besides the MPEG encoding that's already using it.
              • #22
                Well I will see what Edius shows when I fire it up on my PC once I get it all set-up.
                Either way it's going to be faster than my current AMD Dual core.
                Software:
                Edius 8.5 Workgroup
                NewBlue FX
                Hitfilm Ignite
                Vitascene 2
                Newblue TitleMotion Pro
                Smartsound 5.8
                Desktop:
                MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
                Laptop:
                MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
                Cameras:
                Panasonic HC-VX870 4K
                GoPro Hero4 Black
                Panasonic GX8 (Stills & Video)
                Garmin Virb 360
                • #23
                  Mine says "8 Logical Cores" when I start up.
                  • #24
                    Will wait and see. I don't know why Eduis would be hard coded to only look for dual core as people seem to imply.
                    maybe we need someone from Canopus to comment and clarify. Either way if it doesn't support quad cores now it will eventually.
                    I'm certain Procoder3 shouldn't have any problems with the quad cores though.
                    Software:
                    Edius 8.5 Workgroup
                    NewBlue FX
                    Hitfilm Ignite
                    Vitascene 2
                    Smartsound 5.8
                    Desktop:
                    Laptop:
                    Cameras:
                    GoPro Hero4 Black
                    Garmin Virb 360
