titler not working
  • titler not working
    Since upgrading to Edius 6.07
    I cannot get into quick titler. All titling options are greyed out
    this is normal if the antivirus warning was overlooked in the readme prior to installing the update
    you can always uninstall and then install full version and apply update 6.06 (which has no issues with AV software) (5 min and you are back to normal)
      Is there any way I can just uninstall version 6.07
        no, but I don't see a problem
        uninstall EDIUS, reboot
        apply 6.06 update, done
        always make sure the temp folder is empty
