How to close open project after PC crash
  • How to close open project after PC crash
    Hi all,
    I have a new PC which has a nasty habit of crashing with a BSOD right in the middle of an editing session. Something about an Unhandled Interrupt Exception...so much for the new hardware...
    Anyway, when I reboot and try to open the last project, EDIUS displays a message advising that the project is still open (by me) and will only open it in Read-Only mode. I have to save it to a new name, it won't let me use the old name.
    Does anyone know how to close the open project (after the crash) so that it can be opened as normal and saved when done editing?
    Cheers,
    Walter
    Computers should make our lives simpler, not more complicated...
    EDIUS6.08, Win 7 Pro SP1, 16GB RAM, 120GB Intel 520 SSD (Windows & Apps),
    ~4TB HDD total (5 drives, no RAID),
    Internal LITEON iHBS212 Bluray Combo Burner
    Intel i7-2700k Processor, NVIDIA 550GTX/TI, Dual Dell 24" Monitors, Kogan 32" LED TV,
    Sony HDR-XR520V Camcorder (HDD), Panasonic NV-MX300 3CCD Camcorder (Tape-defunct), GoPro HD Hero3 Black Edition
    Your project file is most likely damaged that's why you need to 'save as'.
    If you are in need of the original file name use save as again after deletion of the curropt file or use windows explorer to rename.
    No other way.
    Better get your system in order than you'll never see this issue anymore.
    Tony D.
      Does it crash while using FireWire connection / tape ingest ?
      Tony D.
        Nope...Completely random as far as I can tell.
        I don't have time right now to get PC in order as I have a deadline of a few days. Once that's over I will go back to the dealer and get it sorted.
        I just thought that if EDIUS thinks the project is still open that there may be a flag somewhere I could reset rather than saving the project under a new name.
        Cheers,
        Walter
          Originally posted by wkiess01 View Post
          Hi all,
          Cheers,
          Walter
          before opening EDIUS, open Windows explorer and enable show hidden files and folders
          then go to the location of your project file and delete the lock file
          now open EDIUS and choose the last auto saved file, then "save as" over the top of the original name
            ...go to the location of your project file and delete the lock file
            Thanks Anton, that's what I was looking for...
            Cheers,
            Walter
