How to revert to 606
  • How to revert to 606
    Hello everybody.
    Updated to 6.07 from 6.06, the problem is Edius now does not open SD projects
    and the HD projects that it opens some avi clips are deleted, For the projects that are 100% SD an error message appears "Edius has encounterd a problem and needs to close"
    My system runs on Windows XP and I dont have any anti virus software installed. What should I do?
    Andre
    what i did is system restore but i use W7, if you use something similar (like norton ghost) go ahead, but i guess you can uninstall your 6.07 and reinstall the 6.06
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
      Reboot, clean TEMP folder, install 6.07 again
      Tony D.
        Problem solved , as suggested by Jose Luis, I used System Restore of Windows
        and it worked, the problem was when the 6.07 update made changes to the DirectX files. Windows reverted the changes, so I am back to 6.05
        thanks
          Good to know there is a solution por the rest of us rolling back to previous versions of EDIUS
          Paranova Films
          Cali - Colombia
            new 6.07 update sucks you know what
            I also tried to simply update from 6.06 to 07. All seems to be fine until after restart and it came up with some wierd error. reverted back to previous version via same process as above. Why would this be occuring to some of us but not others....mystery...oh yeah...creators just wasted 1 hour of my time...cool.
