I did not use Edius for a while (maybe 5 or 6 month) Yesterday I did the update to 6.07. Had a little problem first with my antivirusprogram (F-Secure). I disabled it and did the update again. All seemed fine after that. No messages.
Today, I spend the best part of the day on setting in and out points at the 200 clips of my next movie.
When I started working in the Timeline I could not startup the Quicktitler. The three upper options were greyed out. How did this happen??
Is it the update to 6.07? (If yes, how to fix it. There is no qtitler.exe to be found that I can add to the exeptions in my antivirusprogramm, I did add edius.exe)
Is there a setting that has to be changed?
Thanks in advance.
Cors Snijders
Thanks in advance.
Cors Snijders
