Greetings,
I started a project with a 1920x1080 30p preset and would like to change it to a 1920x1080 60p preset. The project is at an advanced stage and it would take too much time to redo everything...
The footage is from the new Sony HDR-PJ760V in 60p. I am also using edius 6.06.
Edius wont let change the framerate of the project. Is this normal ? is there a workaround to do it without loosing the informations on the sequence ?
