Extract images from HD video to print
  • Extract images from HD video to print
    A photographer lost some of the photos taken at a wedding and asked me to extract images from the video. The video is full hd, 1920x1080.
    The only way I can think of is to ctrl-T frames from the video after applying a de-interlace filter.
    The photos are for printing to digital albums. Since the resolution is about half of what a camera would have taken, I want to make sure there is no other way (maybe special software or plugins) that I can extract the highest quality image possible from video.
    Hi Zvit.
    As far as Edius is concerned, there is not really any other way than you are doing. Maybe try two option, I am assuming your footage is interlaced due to your reference of de-interlacing, if so. Change your timeline to progressive and do your still export, and do one from your original interlaced timeline. Make sure to use one of the uncompressed stills options. Now view them in photoshop and try applying a de-interlace filter to the interlaced version, and then compare it to the Edius progressive still. In the past I have had Edius export an interlaced timeline still and it looked correct for progressive viewing, but can't remember how.
    There are many ways to do such things, that I am quite sure you will be advised on. But this method is probably the quickest way that only involves Edius to produce the initial stills.
      The de-interlace from Edius looks fine but I'll do what you said too. Good idea.
      Anyway, it's a matter of faking a higher resolution by bumping up the quality. There are some things I found:
      http://reshade.com/
      And the Topaz plugins, especially the Topaz DeJpeg.
        http://reshade.com/
        Maybe tryout the Edius 3D trial. It has a number of options for re-sizing. You may be able to make a high resolution timeline and let Edius use its new re-sizing functions to match your 1080 footage to a much bigger frame size, then try your stills export from the higher resolution timeline. It may be worth a try.
          You have to apply Levels filter in Photoshop, because you ill end up with wrong black levels-grabs look pail. Stills/Photoshop does not really understand such a thing like YUV levels- this what comes out of Edius. You have to rescale them to full RGB levels.
          Apply Levels filter with 16/235 values.
            Ran through a similar issue with a wedding last year. The high priced photographer did not get photos of many of the bride's family members who were present. (Not a question of lost photos but missed photos.) I ended up pulling snaps from the HDV video footage, and used Photoshop to deinterlace, correct aspect ratio, and othewise adjust the stills. Not exactly the best photos, but far better than none.
              De-interlace and adjust black levels, then you could try out http://www.ononesoftware.com/product...ct-resize/?ind for some higher resolution to go to print.
              Not magic but it helps quite a bit, while no substitute for original taken high rez, it will help you out the mess every-time :)
              Tony D.
                If you want best deinterlacing and best upscaling than avisynth is your friend, but it need some knowledge. QTGMC for deinteralcing and NNEDI3 filters for upsclaing.
                Sorry, but most of these amazing software like one above are piece of sxxx- you rather stay with Edius, dont spent money for them.
                Have a look here:
                http://www.infognition.com/articles/..._shootout.html
                Choose one of the tested images and than you will have a grid will results for differen methods- just clik on the names in the grid to see pictures. When it comes to print NNEDI3 is good, becasue it smooth all jagines and make image look smooth (even if not very sharp). It uses nuearal network aproach to find missing image data to smooth diagonals.
                  Not sure how crap you call crap but it works great on my side :)
                  Tony D.
                    The trick, of course, it to meet your client's expectations.
                      I just said many, not all. Just noted that many of these 50$ "super resizers" are quite crap, so in most cases it's not worth to spent the money at all (even if it's small money).
                      If source is interlaced they key point is to use the best possible deinterlace method- this is most important step.
                      If you want I can try to help- if it's so crucial for you. If you send me interlaced grabs I can deinterlace them for you.
                        This is one that you can get a free trial.
