Here is a copy of a PM that I sent to forum user. It explains the whole workflow for this test.
Here is another test project, this one is made direct from JVC's own footage. The master was made in an Edius 4K timeline, by stitching the quadrants back together using 4 video tracks and the layouter (a process that wont be needed when JVC release the proper transferring software, I hope?) The 4K master looked very impressive, although I don't have a 4K monitor. This was then saved as a HQX file for ease of use as a single 4K file, then the timeline was changed to 1080. To make the files easier to use for web download they are converted to h.264 using the Edius AVC exporter at a high bitrate.
Even though these files have been through some processing and been downscaled by Edius. I think the 1080 versions look very interesting. I have compared them to a few different types of 1080 camera files.Even after all the processing and re-encoding, the resolution stands up very well for a downscaled version of 1080. Considering that the nearest decent 1080 camera to it's price, Sony EX3, still costs way more. The JVC does look like it could be a winner. I will do a similar test when I can get hold of some native 1080 footage. The second file is just a quick process through Firstlight, to give it a more film like gamma. Anyway, see what you think.
