Edius 6 and multi-cam
  • Edius 6 and multi-cam
    Can't believe I couldn't find something on this.
    I've just started using multi-cam in Edius 6 (used to use it in Edius 5) with NX card. In Edius 5, the preview of the Multi-cam screens was always on the external monitor via the NX HD Preview. Now, it is appearing on my main PC monitor. The external monitor shows full screen preview of the active camera.
    Is this new in Edius 6 or have I just missed a setting?
    Martin
    Windows 10 Pro. Gigabyte Z370 Aorus Ultra Gaming mainboard, Intel i7-8700K processor, 32GB DDR4 3200MHz RAM, Radeon R9 270 2GB DDR5 Graphics.
    Samsung SSD Drives for system and mixture of SSD and 7200 SATA for video storage.
    Edius 9.50. Blackmagic Intensity Pro 4k
    Dublin, Ireland. PAL.
    Yes- you did not read Edius 6 manual.
      Go to Page 137 and set the NX as your preview device
        Martin
        this is disabled by default in multicam options, untick enables it
        http://www.videoproductions.com.au/e...ternal-mon.png
          Yep I did! I was searching for multi-cam and couldn't find it.
          Actually, prior to reading the manual a few days ago, I did find that setting and had set it as indicated on page 137. When I used multi-cam last night, I got the results I described. Anyway, I'll check it out.
          Thanks folks,
          Martin
          Last edited by Martin_Gleeson; 03-20-2012, 01:47 AM. Reason: Added some idle thoughts
            Perfect. Thanks Anton.
              Writing manual for such a complicated software like Edius is actually not that easy.
              I think GV should also look into this-any problem rised on the forum (like yours) should be quickly analyzed, as quite often adding one line in manual helps a lot.
              There are quite a lot of things, which could be already improved in manual- good manual is a indication of a good product :)
              Just a bit of topic note.
              What I started to do with every new software- before I start to use it I go through all options/settings and try to predict what they do (and also try them).
              If end up with some doubts I look into manual- this is very good way to get to know what are the possible options- helps a lot later :)
