shot a reception with my ex last weekend and the audio is hot, i had limiter set on and tha agc on. havent had it happen before. anyone up on any good audio programs that may help. i read the the noise reduction filter on sound forge could improve the audio, any input greatly welcomed
fixing audio
Jim, it depends how bad the distortion is.
Sound Forge and other some other audio programs have a Clipped Peak Restoration Plug-In. This plug-in can rebuild waveforms that have their peaks cut off, but there are limits to how successful this can be.
From the Sony manual: "Clipped Peak Restoration should only be used for material in which clipping is minimal. Heavily distorted material with areas where almost all peaks are clipped is often unsalvageable."
If you don't already have Sony Sound Forge, try a Google search for other audio programs that might have this function.Last edited by John Hooper; 03-14-2012, 10:38 AM.Edius 8.53WG, Vistitle 2.8, Windows 10 x64 Pro Fall Update, Asus Z87 Pro, Intel i7-4770K, 16 GB 1600 Corsair Vengence LP RAM, Samsung 840 Pro SSD 256GB, WD Black 2TB media drive, Intel HD 4600 GPU, MSI GTX660 2GB VGA, Coolermaster Silencio 652 case, Noctua NH-U12S CPU cooler, Cakewalk UA-25EX USB audio interface, Cakewalk MA-15D monitor speakers, BM Intensity Pro 4K, PlextorPX-LB950SA BD writer, Dell U2410 Monitor
Can second here, Audition has some good filter sets for noise reduction!Andreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
Originally posted by Andreas_Gumm View PostCan second here, Audition has some good filter sets for noise reduction!Edius 8.53WG, Vistitle 2.8, Windows 10 x64 Pro Fall Update, Asus Z87 Pro, Intel i7-4770K, 16 GB 1600 Corsair Vengence LP RAM, Samsung 840 Pro SSD 256GB, WD Black 2TB media drive, Intel HD 4600 GPU, MSI GTX660 2GB VGA, Coolermaster Silencio 652 case, Noctua NH-U12S CPU cooler, Cakewalk UA-25EX USB audio interface, Cakewalk MA-15D monitor speakers, BM Intensity Pro 4K, PlextorPX-LB950SA BD writer, Dell U2410 Monitor
It depends how bad it is. Sound Forge or Audition would
serve you well. I have the latest Audition, CS5.5, as well as
1,2, and 3.Jerry
I would have slap the crap out of my ex if she let the audio gets hot like that, next time bring your current wife and not your ex.
BTW all my ex live in Texas.:-)I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
Jim,
Can you post a small section of the audio that has the distortion? About 10 seconds would be enough to test.
I would be willing to put it into Sound Forge for you to see if it is salvageable
If it is beyond repair, it could save you the trouble of learning a new piece of software.Edius 8.53WG, Vistitle 2.8, Windows 10 x64 Pro Fall Update, Asus Z87 Pro, Intel i7-4770K, 16 GB 1600 Corsair Vengence LP RAM, Samsung 840 Pro SSD 256GB, WD Black 2TB media drive, Intel HD 4600 GPU, MSI GTX660 2GB VGA, Coolermaster Silencio 652 case, Noctua NH-U12S CPU cooler, Cakewalk UA-25EX USB audio interface, Cakewalk MA-15D monitor speakers, BM Intensity Pro 4K, PlextorPX-LB950SA BD writer, Dell U2410 Monitor
Audition calls it "Clip Restoration." From the user manual: "Adobe Audition’s Clip Restoration filter can remove the evil occurrences of clipping from your waveform. It does this by actually “filling in” the clipped segments of the waveform."
The program offers sevaral parameters to tailor the correction process.
