changing filter on multiple clips
  • changing filter on multiple clips
    Hi- I've tried looking for info on this- if it's out there, please excuse this question, but I can't find it :)
    I often cut multi-cam footage, and while I try to match the cameras before I start cutting, I often find I can do better. Trouble is, once I've cut a sequence, I have many many clips, all with the filter which I want to change.
    What's the best way to change all these at once- rather than going through clip-by-clip, removing the older colour correction, and adding the new one? I'm pretty sure there's a better way!
    Cheers-
    Yes there is!
    Select the clips in question.
    Right-click and pick Delete Parts>Filter>Video
    Make corrections to a single clip
    Select the clips in question (not including your corrected one)
    Ctrl+click your corrected clip (adds to selection)
    Ctrl+click your corrected clip (removes from selection) Its filters are now in the Information pallet.
    From the Information pallet drag your filters to the (remaining) selected clips!
    Now say OMG!
      You are an absolute gem! Thanks Rusty- this has saved me both time and boredom :)
