One of our cranes got flashed by lasers at a Bat Mitzvah and must have damaged the sensor or something and for 47 minutes there are 2 black lines, one vertical and one horizontal, on the right side of the video that I'm trying to figure out how to blur it as much as possible but nothing helped so far.
Attached are 3 frames from the event that you can see the lines.
Luckily, it's 1920x1080 footage so I can scale it a little without it being to noticeable. If I scale it to %109, the vertical line disappears off the frame. The problem is the horizontal line.
I tried to take one frame into Photoshop and did a content-aware fill (thought I'd export it from after effects into a Photoshop sequence and create an action for this) but it didn't help that much. (I de-interlaced the footage first but you can still see a visible blurry line).
I tried various blurs, masks, noise reduction filters, blend modes, and more.
Any ideas? I understand that probably there is no magic filter for this but I don't mind working a little if someone can give me some ideas.
Thanks!
Thanks!
