Bin Favourites
  • Bin Favourites
    Must we scroll through the transitions each time ? Surely thre is a way to set up a favourites list and import selected transitions into it
    Sure, simply right click and Select New Folder. Afterwards, depending on what you do with things, you may have to have to unlock the icon in the upper right hand corner.
    You can not copy effects to the new folder, but you can drag them from your original location. If you prefer to have both, you will need to apply the effect on a clip, go to the information Tab, right click and then Save as a Current User Preset. If you have the new Favorites folder selected before you do this is will save int hat folder. If not you can drag it there.
