Exporting P2 with 4ch audio?
  • Exporting P2 with 4ch audio?
    Customer just called and said he can't output a P2 clip with 4ch audio, just 2ch. Made a brief check and couldn't find an option, either. Am I blind or is the P2 exporter limited to two channels of audio?
    Is the user in a 4 channel out project?
    I'll bet that is not the case.
    Also make sure that if you are in a correct 4 out project to make sure export to 2 channel is deselected . That is if you really want 4 channels out.
      Hi Steve, customer uses the standard full hd 8ch template. Is a 4ch template needed to output 4ch?
        8 channels will go out 8 if correctly mapped. (you can map it to 4)
        If the export to 2 channels is selected the 8 mapped will go out to 2.
        Did the user map for 4 out?
        This is easy to check.
        And a colorbar on the timeline.
        Open the mixer and watch how may channels go out.
        If 2 the mapping needs to be set.
          Hmmm...mapping seems to be correct. Just outputted a XDCAM422 8ch stream. Same project, same sequence gives only 2ch with P2.
            Can I see a screen shot of the mapping?
              Later, I'm currently not at my workstation.
                I think that the mapping is not set correctly. I use P2 and export to any setup channels just fine.
                  Make sure: "Export in 16bit/2ch" is not selected.
                  It happens sometimes, eg. when you use previously used preset (which had it ticked).
