    Using EDIUS 5.5, I have several .pgn logos over video. Can't find a way in 3D-PIP to create a drop shadow. The shadow only appears around the invisible page the logo is on, not on the logo itself.
    What's the trick?
    System specs: Windows Ultimate i7 64 bit, CPU Intel Core i7 970 @ 3.2Ghz (6-core), 4G RAM (Plus 2X4G sticks) , SSD 80G OCZ Revodrive, 2TB X 2 internal HD, NVidia GTS 450, HD Spark, Dual Display, Edius 8
    What's the trick?
    There is no trick I have found. NewBlueFX has a drop shadow that works in one of their effects offerings.
    Another option would be to just add the drop shadow in photoshop before exporting. Of course if you are going to animate the logo to make it spin that may not be the best option.
      Put the logo into a title.
      Glen Meyburgh
      Imagio Productions
      Edius ver. 5.51
      Panasonic AC160
      Canon 70D
        What's the trick?
        Just use Quicktitler and import the logo there. All the nice things like border and shadow will work.
          Exactly, this can be done with any Titler...
          * Quick Titler If the image is inserted, turn on any preset within it and change the file *.png, in question as shown here:
          * Then you adjust the parameters of the shadow and blur ideal for logo, as shown here:
          * Because of this you apply 3DPinP and turns if you want.
          CSXD2 l For EDIUS Pro 6.5
            Great idea....that method had not crossed my mind before. Learn something new everyday.
            And you could rotate it with the layouter keyframes and don't need the 3dPnP.
              Make sure that you put your "title" on a Video track and not in a Title track to apply your 3D PiP.
              Glen Meyburgh
              Imagio Productions
              Edius ver. 5.51
              Panasonic AC160
              Canon 70D
                Inscriber does not "see" any of the logos in either IMPORT or BACKGROUND. The file locations where the logos are is "empty" according to Inscriber.
                Is there some function I am not seeing or do I need to covert to EDIUS in order to get Inscriber to "see" them?
                  in TmPro, go to Logos and right click any of the empty squares to browse for your still
