Layout Bezier problems in Layout
  • Layout Bezier problems in Layout
    Hi
    Since upgrading from 6.03 to 6.06 I'm having real problems with the bezier keyframes in Layout. They used to default to bezier/spline and always produced nice smooth progressive motion. Now they default to linear which is ok but its a real hassel to change them to bezier and not all values can seem to be changed. For example scale seem only to be linear and having problems with rotation as bezier as well. It all just means that when trying to rostrum round a picture which used to work so well, now most the movements are sudden which is just rubbish. Seems pointless having smooth movement if you can't do the same zooming into the picture or rotating it??
    Can anyone help or at least that it seems to be broken for them and not just me...
    Many thanks
    Denham
    Win7 64bit pro, I7 950 running 3.07 at 4ghz, watercooled. 12 Gb ram, Geforce 460GTX with 1GB GDDR5. External firewire 800 drives. Running E6.06
    17" MacBookPro core2duo 2.5 ghz. 4 gig Ram Nvidia graphics Running Win XP pro. Running E6.06
    Pentium 4 2.6ghz running storm2 system on Edius 4.6 with 1gig of RAM and XP pro.
    I will request to bring back bezier as default because (or a user setting option to set it) that is also what I need
    to switch all keyframes to bezier in one hit, right click the very top left one and all others will be changed at the same time
    Anton from sunny ADELAIDE
      Thanks Anton,
      Glad someone else has a similar view. I'm pulling my hair out with this, its not just having to change it, allot of the time I just can't see it working?? Change the key frames when values are expanded and you see a curve but still the motion has no inertia. It worked so well before and to be honest hardly ever needed to change anything to linear. I'd be able to do this quicker with better results in AE which if daft for a simple rostrum movements.
      Just another quick note... when I drop a still image/colour matt on the time line, instead of it dropping on centrally the top left hand of the image centres on the top of the screen so that the image is half way off?? Have to keep going into layout and select it to default. Is everyone else getting this in E6.06?
      Denham
        Sorry to say that from the requests we have had, you are in the minority in this. That is why it was changed. Of course a setting to determine which is the default would be ideal.
          Strange that only the minority wants Bezier, without it it's no fun .......
          Tony D.
            You can add me to the "minority" that would like iy changed.
            i7 3930K, Win 10 pro 64 Bit.
            RAM 32 GB.
            ASUS P9X79-Deluxe.
            PS Thermaltake 1kW.
            Graphics Gigabyte GTX1660 OC.
              You can also add my name to the minority list.
              BigRick, Montreal, Canada
              EDIUS 8.3 with HDSpark - Intel I7-3770k, 16 GB Ram, Windows 10 64bit Home Premium, ASUS GF GTX560 TI 1 Gb Video Card and Intel® HD Graphics 4000, 2 X LCD 24" Monitors (1920X1200), 1 X LCD 32" Television
              1 SSD Samsung 500 Gb (System),1 SSD Samsung 500 Gb (Video data), 2 X 3TB Sata II, and others
                You can also add tdtinker to the minority list.
                tdtinker
                Edius 8.5
                www.actvp.com
                  Guys this is not a poll. Please follow the procedure of a request byusing PM to either Steve or myself
                    Originally posted by shootncut View Post
                    Thanks Anton,
                    Denham
                    sounds like your layouter has some values saved as a default, in that case, click reset all and save as default
