SHX-E2 driver
  • SHX-E2 driver
    I recently had to reinstall Edius 6.02 and the 6.03 upgrade. Since then My SHX-E2 is not recognized. I remember from the original install that I had a hard time finding the drivers. Where are they available? I thought they were on my Edius 4.5 disc, but the closest I find on there is the HX1 audio driver.
    they are part of the 6.03 update, but you should be updating to 6.06 which has newer drivers
    look in the 6.03 or 6.06 installation files and you will find the hardware drivers folder, it covers all supported hardware with a single setup.exe
    http://www.videoproductions.com.au/e...re-drivers.png
      Thank you Anton, All is working now.
