. . . application configuration is incorrect . . .
  • . . . application configuration is incorrect . . .
    Suddenly after years of everything working great I am getting an error message:
    This application has failed to start because the application configuration is incorrect. Reinstalling the app may fix the problem.
    I have uninstalled and re installed, even reinstalled on a different hard drive and still get the same message. I did install and run Neo sucessfully but Edius 5.5 is not starting. Running on Win. XP Pro. HELP!!!!!!!!!!!! any ideas?????
    are you trying to run Neo and EDIUS 5 on the same PC?
    do you have a soundcard and is it working? EDIUS 5 will not start without one
      I had exactly the same problem a few months ago.
      Luckily I had a clone of my boot disk and that worked OK so I ended up cloning the clone back onto the troublesome hard drive.
      My post advising of the problem did not get any solutions that worked.
      In your case if you have an image of your boot drive I would use that to restore to a working system.
      If you do not have an image or clone then I think that you are into a full Windows re-installation and a new installation of all your software.
      After that all should be OK, then get Acronis True Image and make a drive image and boot media for next time.
      If you would like to replicate my system get two off trayless caddies for your hard drives and put them in your system, the boot disk slips into one of the caddies and another hard drive into the other then it is a simple matter of using True Image to clone the boot onto the blank hard drive, once cloned take out the clone disc and store it safely (suitably labelling it).
      It is a pain to set this up but once done in the event of a problem you can shutdown the PC and swap drives and restart working (you do have to have all the scratch discs and project files on another video drive etc for this to work successfully)
      Good Luck
        and if you have Win7, you can create an image in minutes and restore it in minutes with all software remaining activated, all built into Win7
          Where in Win 7?
            Try Control Panel-Backup Restore-Create a System Image and also Create a system repair disk
              you don't need a repair disk as long as you have a Win7 DVD
              to wipe the C drive with an earlier created image, boot from Win7 DVD and choose restore system from image created earlier, it will then find the image as long as it is on a secondary internal HD
              never create an image on a Raid
                Thank you! Not exactly what I wanted to hear. I guess I will set up a dual boot system so I don't loose all my current stuff and just put Edius and any other editing related software on the new Windows XP partition.
