Capture Greyed out for HDV?
  • Capture Greyed out for HDV?
    I can't seem to capture HDV. The capture button is greyed out.
    I have done this before in 6.05, but this is the first time I have needed to do this in 6.06. I have previously made a HDV preset which has worked. I attach a screenshot of the preset.
    I am using a Sony HVR-A1E PAL camcorder for replay. The Firewire out is working, as I can capture DVCAM using the same camera and cable. The output on the camera is set to HDV and not Auto. The iLink on the camera says HDV out and I can view the video on the camera screen.
    Anything I might have missed?
    John, what you have displayed is the project preset. You need to set up a capture preset .
    Go to Settings>Hardware>Device Preset. Then set up an hdv preset for your device. This is, more than likely. the reason for it not showing up.
      Hi Jerry,
      Sorry I should have screenshot the device preset. I have this already set up and used it before.
      I have now identified the problem, but not sure why it had got changed. The device preset was set up for OHCI and not Generic HDV.
      All working now, thanks for pointing me in the right direction
      Here is that screenshot.
