Fade outs are hesitating
  • Fade outs are hesitating
    Hi, i make my fade outs by giving manual curves to clips at the timeline window track panel (see screenshot). But during the playback (in the timeline or in the exported file) the movie pause or hesitating a moment at most of the fades and of course the smoothness disappears. Sometimes this occurs even at simple A to B cuts.
    This is very important for the general quality perception of the films. So please i need to hear your advices about smooth fades.
    Best wishes.
    Murat
    6.06 with NX for HD, Win 7 64 bit.
    1. Intel D5400XS mainboard, GTX660, Dual Xeon X5450 CPU, 1 TB + 2X2 TB, 8 GB Ram, Edius NX for HD, E7.4, Win7 64 Bit.
    2. Asus X99 Deluxe, Geforce GTX 770, Intel 5960X 3.0 GHz, GSKILL 32GB DDR4, 250GB 840 EVO + 2X4 TB, 2X27" Philips IPS, 26" Samsung TV, Win7 64 Bit, E7.4 and HD Spark.
    - EX1R, HXR-MC50E, 5D Mark II, Lumix GH4, Hero4 Black.
    - Rode NTG2, NTG3 and lavalier mikes.
    - DJI Phantom-2 with zenmuse H3D.
    - Sea&Sea housing for 5D Mark II, Ikelite housing for Sony HXR-MC50E.
    You see the red line on the clip after the fade? that means your computer can not play it in realtime that is why it is not smooth around the fade area, your computer must be very slow or you have too many effects on that clip, you can try to put the cursor a few seconds before the fade and hit shift + space bar and let the load the buffer and see if it play smoothly, if so then for sure your computer is too slow.
      Hmm may be you're right. Then i want to ask something, when i finish the project, should i make all the project RENDER before exporting? I suppose if i do this, it will be helpful for smooth exporting. What do you think about?
        Rendering is not required for exporting.
        It is up to you .
          It is up to you .
          Ok, full render is a kind of suffer already. :)
            If you could, post your system specs in your signature. It helps us help you.
              what happens if you add a dissolve to the keyer tracks for fade in/fade out instead of opacity changes?
              http://www.videoproductions.com.au/e...ransitions.png
