Problem Upgrading to 4.5
  • Problem Upgrading to 4.5
    Currently have V4.13 on my machine. Went to insall 4.5 upgrade from web site. Install was interupted.
    Now when I go to install get error message "Different version of EDIUS was detected. This setup will not proceed."
    Edius 4.13 runs however I get the message that the version has expired and I have 30 days. The dongle is in the USB port.
    I tried to uninstall V4.13 however I get the same message that it's a different version of EDIUS and setup won't proceed.
    Any ideas what should I do?
    Please try and re-install 4.13 and then try the upgrade again. Sorry abouit the trouble you are having!
      Thanks Mike, currently I can't un-install 4.13. When I run the Un-install I get the same message. If I try and Install 4.13 over the top I again get the message related to it being a different version of Edius. Is there any other way I can try and un-install?
        Problem Solved
        Rolled back XP to prior to installation attempt. Re-installed fine.
          Awesome... I am glad it worked! :)
