I'm not sure if it is designed to work this way, but.....
I had a clip on the timeline, fading in using the blue rubber band.
Thought it might look a little better if it was slightly zoomed in, so I used 3D PiP to zoom in a little and the fade in stopped working. I had to go back in to 3D PiP and add transparency to achieve the fade.
Graham
Graham
