VHS to Edius
  • VHS to Edius
    Trying to get VHS from a Panny 1980 into Sony PD-170 and then firewire into Edius. Done this many times without any hassles. All of a sudden I am experiencing the following. Any suggestions? Tried rebooting and all the obvious things.
    The pass through is visible on Edius player window. When I press capture button there is total blank and capture is not recognized. When I hit stop on capture the player window resumes the signal. Everything is there but the capture process. Any ideas???
    Thanks,
    Ara
    Figured it out. There was a tape in the camera. As soon as I removed it everything became active.
    Thanks,
    Ara
      Glad you solved your problem. For others with similar problems, sometimes its a bad cable contact. It helps to use different cables to eliminate that as a problem. It's usually the simple things that cause problems!
      Regards,
      Jon
        Amen to that. I spent two hours on this today. All of a sudden light dawned on Marblehead. How is SD these days? Spent three years in El Cajon in the early 80's and worked at Grossmont Hospital?
        Thanks,
        Ara
          Ara,
          I PM'd you.
          Regards,
          Jon
