Alpha Channels Transparency
  • Alpha Channels Transparency
    Hi ,
    Is there a way to change the alpha channels default transparency color of black to the checkerboard white/grey blocks pattern?
    Thanks,
    Chris
    Proud user of EDIUS!
    Hi Chris,
    Unfortunately having a checkerboard background is not possible in Edius unless you have an offline clip so i guess the only option is to stick with the black background.
    EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
    Sys 2: Asus ROG G75series
