Same old driver problem again HX-E2!!!!
  • Same old driver problem again HX-E2!!!!
    Nothing new has been added to this system, but this morning it has decided not to recognize the the NX card. I have uninstalled and reinstall the device 3time but all I get is "windows encountered a problem installing the driver."
    Any suggestions????
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
    Anyone????
    tdtinker
    Edius 8.5
    www.actvp.com
      uninstall the hardware drivers
      reboot and confirm in device manager that there is an unknown device, if not, see if you can uninstall it from device manager and reboot
      http://www.videoproductions.com.au/e...-uninstall.png
      empty temp folder
      install EDIUS hardware drivers
        What was the minimum version for NX, 6.03?
        Just installed 6.00 to 6.05 NX on a new system, no problems!
          I had no problem until two days ago. Nothing has been added to the system. It just decided to stop seeing the card. After deleting and restarting the system 3 times today it finally as seen the card. Strange?
          TDTinker
          tdtinker
          Edius 8.5
          www.actvp.com
            TDTinker
            I am beginning to suspect a bad mobo
              Anton's probably right. Either a BIOS incompatibility issue, a physical installation issue (not seated right), or a motherboard component going/gone bad.
                I had something similar with my NX card. Took it out and reseated it - all ok.
                Peter
                Pete Silver
                Edius 7 Vistitle 2
                www.psilver.com
