Crash in 6.05
  • Crash in 6.05
    Problem Event Name: APPCRASH
    Application Name: EDIUS.exe
    Application Version: 6.0.0.49
    Application Timestamp: 4e4d5351
    Fault Module Name: WMVCore.DLL
    Fault Module Version: 12.0.7601.17514
    Fault Module Timestamp: 4ce7b980
    Exception Code: c0000005
    Exception Offset: 00030002
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 2057
    Additional Information 1: eb29
    Additional Information 2: eb297789c49e99d954412f0e4f8870ab
    Additional Information 3: f665
    Additional Information 4: f66512ec65d907ab140e4323623f4107
    Read our privacy statement online:
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    EDIUS
    Exception occurred in sequence export conversion.
    Unknown XML media file (90020002).
    OK
    Had this whilst running PluralEyes on a sequence, after a restart lost the HDStorm HDMI Output on the monitor. Had to quit and restart EDIUS.
    You wrote:
    "Exception occurred in sequence export conversion.
    I think this points to an issue with Plural Eyes and/or the clip(s) in question.
    Which version of Plural Eyes are you running? The screenshot below shows the limitations with the latest version.
    Have you reported this to Bruce @ Singular Software?
    Try removing the clips, one by one, which you are trying to sync with Plural Eyes to identify which might be causing the issue.
