how to read canopus AVI
  • how to read canopus AVI
    hi
    I did a capture from HI8 and I can not watch it on my TV
    Sony CCD-TRV48E PAL+ADVC110, Sony DCR HC90E, Sony HDR CX360VE,Gopro Black Edition 4Kp
    How is your TV connected to your computer? What software are you using to try to play the video?
      My TV can read divx from my synology server or from usb key
        I tried to read it like a movie I got only sound
          Can you explain what you are doing?
            Originally posted by ggdn View Post
            hi
            Do you want to play out the captured material with a Media Player device (either stand alone or built in into a TV)? If so then you can't do it with Canopus *.avi because the Media Players can't read it. Convert the files to Mpeg2 or Mpeg4 first.
              yes I wanted to read the captured material with my TV
              is ti possible to convert into Mpeg2 or Mpeg4 with edius?
                yup, you can convert it to many formats as you want.
                Press F11, look and smile. Any format you want :-) Edius make it possible.
                ciao
                Werner
                Werner Weißböck
                [SIZE="2"]X-trem production, Austria
                  and mpeg2 export is very fast, uses all cores at 100%
                  place the mepg2 on USB stick or drive and insert on TV USB slot, works great, who needs Blu-ray?
                    thanks it exatly what I needed
