Exporting
  • Exporting
    Hi guys,
    On my timline I got video only I deleted the sounds and i put musics on audio tracks , all my audio tracks are on i made sure that the audio tracks are not mute, everything looks good ,but when I exported and I play there are no musics . any help please,
    Thank you
    Need more information.
    What version of Edius? What are you exporting to? What is the format of the timeline?
    Does the audio play directly out from the timeline?
      Exporting
      Hi John,
      I am using version Edius 6
      I exported with mpeg. as most of time I do,yes the audio play directly out from the timeline. the first time i am having this problem.
      and thank you for your responds.
      John
        which version EDIUS6?
        what kind of mpeg? program stream, elementary stream? mpeg2? mpeg4?
        if mpeg4, it is a known issue caused by the latest Quicktime player 7.7
        you can uninstall QT player and then install the one that came with EDIUS installation DVD
        EDIUS 6.06 when released will support QT player 7.7
          Exporting
          Hi,
          I go Edius 6.01.I used mpeg2 program stream.
          but I just found out that when I export it renders audio and video individually.
          I am not sure why is doing it .thanks for your help.
            Originally posted by John123 View Post
            Hi,
            1. you have chosen elementary stream export by mistake, choose program stream then audio will be part of video
            2. update to 6.05 asap
              Exporting
              Hi Anton,
              Thank you so much I got it
