audio waveform disappear
  • audio waveform disappear
    after working with a project for about 2 to 3 hours, when I try to contract or extent a timeline, audio wave form disappear at once, for all audio tracks! this happened many time before and now it becomes more frequent, RAM problem? or Edius 5.5 problem that cannot be solved?
    btw, any schedule for NHX Edius 5.5 upgrade to 6.05?
    It is a problem in EDIUS 5.xx EDIUS 6 is much better in this regard.
      NX works with Edius 6.05 and has for a bit.
        thanks and then....
        thanks for the clear answer,
        btw, any info on upgrade to Edius 6? Or I just simply buy a Edius 6 at shop and forget about my Edius 5.5?
        henry
          Yes there is an upgrade path. Here is an example: http://www.sharbor.com/products/GRVN0320038.html
          Whether this is any good for you in Hong Kong, who knows. But you could contact the GV dealer in the area.
            thanks
            thanks for your useful data on Edius 6 update, yes, I will ask a HK dealer or ask my friend to buy at USA,
            by the way, is this a software upgrade or, additional hardware will be included?
            henry
              It is a software upgrade. If you have a Thunder card, it will provide a firmware update that will change it to the Storm3G.
