Problem with using Panasonic p2 avc-intra 100
  • Problem with using Panasonic p2 avc-intra 100
    Hello, we bought a new computer for editing panasonic p2 avc-intra 100 hd videos.Edius 5.51 doesn't respond after importing the hd p2 video into bin.I did upgrade bios,uninstall and install edius again.But what I did for solutions didnt solve the problem.What do you recommend for solving the problem.thank you...
    System configuration is below:
    intel i7-2600K [email protected] 3.40GHz 3.40 GHz
    8 GB ram
    OS: windows 7 ultimate 64 bit
    Harddisk configuration: 4 TB raid 0
    Mother board:Asus p6h61-m le/usb3
    start here and then try again
    http://www.videoproductions.com.au/html/win7-tips.html
      I forget, did Edius 5.x require the AVC-Intra addon and dongle? For what it is worth, I'm editing AVC-Intra 100 using Edius 6.05 and it works extremely well.
        No dongle needed for 5x it should work.
        Dave.
        www.nakedeyedv.com
          I can edit avc-intra 100 files all day long on a core 2 quad running at 3.54.
          That new machine should work fine with them.
            problem was solved
            thanks a lot Antonsvideo.I did what you typed the link above.It solved.
              Don't forget to send Anton beer for Christmas.
              Atari 400
              JohnFellersProd
