Background Music Audio track playback .
  • Background Music Audio track playback .
    Hello Guys,
    I have a strange audio problem. I placed music for background on an audio track, and whenever it reaches a transition (during playback) that is placed on the regular AV track , the audio on the background track stops playing for duration of the transition. (This background track has no transitions and shoud play continously) Any ideas ?
    System: Edius 6.05 MB: ASUS P6X58-E WS LGA 1366, Intel Core i7-990X Extreme 3.46GHz, 12 Gig, Windowa 7 Prof.
    What is the transition? if it is a 3rd party type, it might need to be rendered.
    Also is the audio track a 16 bit 48Khz WAV file?
      The Transitions are regular desolves in Edius
        What happens if you unGroup the V & A and move the music onto a separate Audio track. Does it play properly through the transitions then?
        Also, are you sure the transitions are only video and are not audio cross fades as well?
        Intel Quad Core Extreme 3GHz/12M, 4Gb RAM, 2Tb Hot-swap (ARAID), NVIDIA GeoForce 8800 GTS, Edius Broadcast 4.61 / Edius 5.5, Procoder 3, DVDit Pro HD, Sonicfire Pro 5, Mercalli, Vitascene, Adorage. TwinPact 100, Pegasus, TMPro. VirtualDub
          What I have further found, is, that it plays fine when playing direct from the system audio output (on the system mother board). Once its played out through firewire to my DV deck the problem occurs. The sound stops after the timeline cursor passes over the transition.
            What file type is it? .wav, .mp3, .mp4?
            Sounds like a problem with VBR audio.
            Convert to CBR .wav and your problems will disappear.
              They are MP3 files.
                Try converting them to .wav files.
                  I converted to wav as suggested, but the problem is still there. Is there some setting for firewire that may have been over looked, or is this a problem with edius 6.05 ?
                    Can you post a screen-grab of your timeline?
                      What does a firewire setting have to do with the audio playback?
                      Screen shot definitely would help.
                      MP3's are not good for editing and syncing. Stick to .wav's. Do you have the same problem when you put a different audio file in the project?
                        I will post it later this evening.
                          Only mentioned firewire, because this only occurs when I output via firewire to my DV Deck for DV tape printing.
                            How are you outputing via Firewire?
                            Are you using any hardware and also are you using Print to Tape?
                              I plug the firewire form the system to my JVC DV deck. This how I did with my other systems running Edius 4.61, the only difference is that both of the other systems had the DVStorm card and I never had an issue until now.
