Hi just followed the link to utube H264 setup on the GV thread above and there is only AAC low complexity not AAC as show in guide and also no bit rate target. What is the difference and is this ok?
Check out the example further down in that thread, it has a youtube example and Edius 6.05 settings.
You could of course use other methods, but in all fairness using Edius 6.05 direct from timeline will give you very little difference at high bitrates and a much quicker workflow. Just use the same AAC output, and all will be fine.
