Speed Encoder
  • Speed Encoder
    Can somebody with Speed encoder and Edisu 4.24 test this for me, encode about 30 seconds of a section on your timeline using in and out marker, when it is done bring it back up to timeline and see if the new .m2t file is the same lengh as the in and out marker, mine is always longer, do the same thing using ProCoder 2 and all is fine.
    Thanks in advance.
    Speed encoder
    Uh oh!
    I like speed encoder, but... not much success, yet.
    I'll check this one tomorrow!
    Rusty
      我想问一下,系统可不可以在后面翻译成中文呀
      like :
      "Uh oh!
      Rusty"
      “噢 ,我喜欢速度快点的编码,但……还没有成功,
      明天我还要检查一下这个,
        I tried it with precisely 30 seconds between in and out, and the file that came out was precisely 30 seconds long, to the frame.
        Desktop: Intel Vernonia-R Server Board, dual Xeon 5420 2.5Ghz (8 cores), Vista Ultimate 64 Bit, 12 GB RAM, NVidia 9800Gt 512MB graphics, 320 GB system drive, 2x1TB Seagate editing drives (not in RAID), 30 inch HP monitor.
        Laptop: Toshiba Portege R700 2.66 Ghz cpu, 4GB RAM, 500GB hard drive
          Thanks for checking, now I know that it is my system and not the software, I made a 2 minute file yesterday and it came out almost 1 hr. long, something is screwy, I can not reinstall from the installation disc, it said "Edius not found" I can not update it either, and I can not find it in add/remove program to uninstall so I can reinstall, do you guys know where I can uninstall if from?
