anyone know if there is a newer version of mpeg capture? mine is 4.02 and is outdated, RT buffer limit of 96 and no ac3 audio and it fails to set a 16:9 flag
Mpeg Capture
Mpeg Capture
EDIUS X WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 ProTags: None
I checked the README.txt and it's 4.02, same as yours.
tuyle
Originally posted by antonsvideo View Postanyone know if there is a newer version of mpeg capture? mine is 4.02 and is outdated, RT buffer limit of 96 and no ac3 audio and it fails to set a 16:9 flagAsus X99-A/USB3.1 - Samsung EVO870 1TB - Win10Pro - Edius 7.53
As a matter of fact, there is! It's on the new 4.5 DVD-ROM media being shipped. I'll archive it up and put it in the downloads section.
This is an excerpt from the readme:
Version 4.02 Release: 09/01/2006
- Fixed issue with captured MPEG files (invalid data was added at end).
Version 4.03 Release: 12/01/2006
- Fixed to detect the aspect ratio when the input source is DV.
- Fixed the setting dialog audio page to show the current setting correctly.
Version 4.04 Release: 02/14/2007
- Supported DVX-E1.
Version 4.05 Release: 06/01/2007
- Fixed issue when using DVX-E1 with PAL mode (the application did not work correctly).
mine tells me it is 4.00.00 which seems incorrect, then again it maybe? I was expecting it to say 4.05Anton Strauss
Originally posted by antonsvideo View Postmine tells me it is 4.00.00 which seems incorrect, then again it maybe? I was expecting it to say 4.05
- Readme.txt
- CMTSWriter.exe from version 4.02.001 to 4.04.001
- mdccts.dll in PlugIn folder from version 4.02.000 to 4.05.003
So I’m thinking that the dll is where most of the work is done and the exe is the interface only.Rob
