Edius 4.5 compatiable with 5.5
  • Edius 4.5 compatiable with 5.5
    I edited a project in Edius 5.5 will it open in 4.5? I have a client to deliver this project to and they only have 4.5 If not is there a work around for this?
    Many Thanks
    Lauri
    Using Edius 6
    AS the rule has always been. Newer EDIUS version projects don't open in older versions but older version projects open in Newer EDIUS.
    So 4.5 -> 5.5 will work.
    4.5 <- 5.5 will not work
      send them a Canopus HQ Fine
      and tell them to update to 4.61 (free) and much better than 4.5
        You can also try exporting the project as an EDL (Edit Decision List) file.
          never had any luck with EDL and EDIUS
