AVIs with unknown audio
  • AVIs with unknown audio
    Hello all- I'm using Edius to create AVI files. These are AVIs with uncompressed YUY2 video. The audio is 48kHz/24bit, but I can't figure out what codec is being used for it. I'm attaching an export from MediaInfo which tried to identify the codec. Also, when I play the file in VLC the video works fine, but I get a message that the audio format is undf.
    What would cause this and how do I fix it? Thanks in advance!
    The files contains just 8 uncompressed PCM audio channels! ;)
    Maybe VLC has some issues with multichannel files?
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      Thanks Andreas! What do you think about the fact that MediaInfo reports it as that weird long string of characters?
        Have no issue with that! Normal state!
        It seems to be just a hexadecimal code for the codec!
        Just search by Google & look what other users say!
        http://www.google.com/search?q=00001...0-00AA00389B71
        Andreas Gumm
        Windows 7 Ultimate,
        PC 2
          not all software can handle 24bit audio
          export to 16bit and it should work fine
          and does your source really have 8 channels? In EDIUS6 it is easy to accidentally make 8 channel presets instead of stereo 2 channel because the project wizard defaults to 8 channels
            Hi Anton- Thanks for info! This is helpful. MediaInfo is able to recognize 24-bit audio with the AVIs we make using another system. Attached is the info for those files that have easily identifiable audio. They only have 4 channels of audio so maybe that's the difference?
              In v.5 is there a way to change the number of audio channels to be captured? Is this a hardware or a software issue?
                wow, 24bit 96k audio now, this should make most software fall over
                  don't understand the question
