Hi all,
I have Edius 5.51 (but noticed the same problem in Edius 6 demo).
When I insert a clip with audio, if I select a single audio channel (e.g., properties - audio info - channel 1) the channel 1 volume decreases.
For example, let's say I see that the Channel 1 volume is 8 out 10 and Channel 2 is 3 out 10. Then, when I select properties - audio info - channel 1, I get Channel 1 with a volume 5 out 10 and Channel 2 with a volume 5 out 10. Is this normal? It should be both 8 out 10 (the original Channel 1)
I'd just like to "copy" what is in the first channel of the clip to its second channel.
Any suggestion?
Thank you
Any suggestion?
Thank you
