Using F11 to capturev still today i encountered the following problems, previously i used the capture button to bin but stopped because deleted file numbers were being re used
1 Having the capture window open reduced my buffer to 5 and therefore jog shuttling was difficult.
2 compared to using Bin you cannot drag to preview window to see on external monitor
3 I placed window on on my 2nd Edius monitor i dragged the corner to make the capture window full size. This window locked to full size and i couldnt rezise to a smaller size, none of the handles worked.
When i switched back to single monitor this window covered the whole of edius no resize and the only way was to close the window
Opening any old project produced the same result and when opened it would show the grabs from the project i was working on
In the end i did a roll back to restore window size. Rezise works when window is smaller
Was No3 a windows or Edius problem ????
