Change SD format project into HD format project
  • Change SD format project into HD format project
    Hello,How do I change an SD format project into HD format project?
    Thank every one
    go to project settings and select a suitable HD preset
    then apply at least 20% sharpness to each clip
    why do you want to do it? there is nothing to gain
      Hi, I mean my format project is SD and i change it to HD without edit my project again.
      Now How do I?
        Just switch the project to an HD project.
          Settings>Project Settings double click an HD preset (assuming you have made one)
            you have 2 options
            option1 = is easiest if you already created a HD preset
            option2 = you modify the existing SD to HD
