Problems
  • Problems
    Any ideas on why my waveform on the audio(wav file or audio from the clip) disappears on a frequent basis. When I restart Edius they come back. Also Edius is very slow lately. Quite often I make an edit(any edit) and Edius takes 15-30 seconds to complete the task. This is getting frustrating.
    Thanks,
    Ara
    This is a known issue in EDIUS 5.
    EDIUS 6 is better in this regard.
      Is this a known issue on both my problems? Is there a fix?
      Thanks,
      Ara
        Purchasing an upgrade to EDIUS 6.03 is the best solution for disappearing waveforms.
          something wrong
          I hardly ever have waveforms vanish when using Win7 and E5.51 and edits are instant, can't blink that fast
          check event viewer and device manager for clues, also check disk management to make sure all disks show healthy
          also, check all hard disks with diskspeed.exe and report your findings of max read speed www.roadkil.net
            When Edius becomes fully gown and enters the 64bit playground, the waveform & constantly rebuilding of thumbnails in the bin should be solved :)
            None of my 64bit apps show any of these signs.
            E5.51 + E6.05 / NX HD / Win7 x64 / intel X3366 / 9800 GTX+
            Imaginate 2 / TMPGEnc VMW5 / TMPGEnc AW4 / WaveLab 4.
              OP is using Vista at least that is in his signature.
                I have never tried Vista but I can't see that as a problem
                  As I wrote this is a known issue in EDIUS 5.xx .
                  We have improved this in EDIUS 6
                  If you have not seen this that's ok but there are users who have seen this and have reported to us way back.
                    yes, I agree about the vanishing waveforms, but I think the OP is more concerned about the other issue
                      The other issue is strange I agree.
                      A system problem most likely.
