Hi there. I'm editing a clip and change its speed for example from 100% to -100% (reverse). When I try to see it, the clip stays the same as long as I don't cut it or change its position. Shouldn't the clip change and the rendered file be forgotten and overwritten? Thanks!
I change a clip's speed and it stays the same
3,07 gigahertz Intel Core i7 950
64 kilobyte primary memory cache
256 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Hyper-threaded (8 total)
12 Gb RAM
Board: ASUSTeK Computer INC. P6T DELUXE V2 Rev 1.xx
Bus Clock: 133 megahertz
ATI Radeon HD 4670
Edius 6.05
Windows 7 - 64 bit
Tags: None
Sounds like you have a rendered file of your clip. Remove the rendered file from the timeline to see your speed changes. Then, render again if needed.Documentaries and Art Projects
Hudson Valley, NY
i7 8700K @ 3.70 Ghz/16 gb RAM
windows 10
284 gb SSD boot drive
2 TB work disc
2TB storage disc
EDIUS 9.52.6031
It's not a matter of being unable to change the speed in the clip, it's a matter of making me have to displace or change some of the clip's properties in order to lose the rendered file so I can see the change I made to it. It's annoying.
64-bit ready
12 Gb RAM
ATI Radeon HD 4670
Edius 6.05
Windows 7 - 64 bit
I've indeed used it. What's the difference between doing it with shortcuts and using the track render commands?
64-bit ready
12 Gb RAM
ATI Radeon HD 4670
Edius 6.05
Windows 7 - 64 bit
Depending on which render method you use you will get different out comes.
Shift+q put a clip on to the rendered area any change to the original clip , you have to delete the clip which was created to reflect the new change.
If you use clip +g clip render no file is extra file is put on the timeline. You can freely move the clip on the timeline and the render stays in tact.
Any change to the clip just use shift+ g again.
Downside : does not support alpha yet.
Render red /orange
No extra clip is created and the section of the timeline can be moved. Render follows.
Originally posted by mattie View Postsounds more like track-synch is on - this can sometimes prevent any speed changes taking effect - turn the synch button off - head of each track rightest most icon/button thing. just turn it off for the track yr clip is on.1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
Originally posted by Dockelektro View PostHi there. I'm editing a clip and change its speed for example from 100% to -100% (reverse). When I try to see it, the clip stays the same as long as I don't cut it or change its position. Shouldn't the clip change and the rendered file be forgotten and overwritten? Thanks!1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
If a clip was rendered at 100% speed, isn't is logical that adjusting it's speed to an exact reverse value only requires the software's playback logic to play the clip backwards i.e. play the already rendered (green) portion backwards? No re-rendering is needed i.e render files need to be manually removed...
Changing the clip's speed to reverse has always required me to render it, more so if it has a couple of vitascene filters added to it, as you can imagine.
64-bit ready
12 Gb RAM
ATI Radeon HD 4670
Edius 6.05
Windows 7 - 64 bit
