Digitizing thru HDMI Cable
  • Digitizing thru HDMI Cable
    Ok I have the Sony Z5 U and I am trying to view the video from my camera
    in the Edius window but I am not sure which capture mode to select.
    I selected the Canopus HQ 1440 X 1080 29.97 but no luck it is not recognizing the camera. I am trying this on an acer 5750 computer which has an HDMI
    port.... Any suggestions from anyone? I have the i link on the camera set to on
    Thanks so much for any help
    Lauri
    Using Edius 6
    you need to select Generic HDV if HD recording and Generic DV if DV recording, and then choose Canopus HQ as your preferred capture codec
    and you need a firewire cable :)
      At this point I don't want to digitize I simply want to see the video from my camera on my computer monitor is this possible?
      When I connect the camera via the HDMI cable to my tv I don't have a problem. I am using windows 7 and edius 5.5 Isn't the principle the same?
      I tried your previous settings and I still can't get the video up on the Edius monitor
      Using Edius 6
        if the PC Mon has HDMI in, then connect the camera to PC Mon HDMI input and switch the input selector on the monitor to HDMI
        is the camera output HD or SD???? this can be changed in camera setup menu
        You will never see an input from HDMI on the EDIUS 5.5 preview mon, this is not supported
          Camera out is HDV silly question how do I changed the laptop monitor to HDMI? Camera output is set to 1080i/480i It is hdv
          Using Edius 6
            ahahhh, a laptop with HDMI input? are you sure it is an input? never seen one
            first thing to do is close EDIUS and see if anything appears on the monitor, if not, there must be a menu to change the input
              ahaaa it's not an input it's an output no wonder why it doesn't work....
              Since we are on the subject my laptop doesn't have a fire wire so how would I digitize footage? If it is even possible geez I'm so technically challanged!
              It is a Acer Aspire 5750-6677
              Using Edius 6
                I am not sure if an addon firewire card is available for this one? can you ask where you bought it?
                  I will need to send a note to the manufacture.
                  I didn't purchase this at a per say computer store....
                  Thanks for all your help as always
                  Lauri
                  Using Edius 6
                    If your laptop has a PCMCIA slot you should be able to buy a firewire card for it. Some of those cards even have dual firewire connections.
                    Bob
                    Edius 8.1wg, Intel Core i7 Extreme 965 8-Core 3.0GHz, 12G RAM,
                      It has a slot that is compatible with SD, MS, MS Pro, xD and MMC cards
                      will that work?
                      Using Edius 6
                        I copied and pasted this from the quick set up guide.
                        Multi-in-1 card reader Accepts Secure Digital (SD),
                        MultiMediaCard (MMC), Memory Stick
                        PRO (MS PRO), xD-Picture Card (xD).
                        It's an acer 5750-6677
                        Using Edius 6
                          Do you have the HVR-MRC1K with the Z5U ? Looking up the spec your laptop only has USB2 interfaces so you cannot capture HDV or DV to it from the Z5U over IEEE1394. If you have the HVR-MRC1K you can use the card reader to transfer from the card to the PC.
                          Ron Evans
                          Ron Evans
                            No I don't have the HVR-MRC1K. Do you think I can buy a fire wire card for it?
                            Lauri
                            Using Edius 6
                              No. It doesn't seem to have any other interfaces other than USB and ethernet.
                              Ron Evans
                              Ron Evans
