Hi All,
I encountered a 'Hardware Error' message whenever i started edius project using NX-E1 project settings like NHX-E1 SD PAL - 720 x 576 50i 4:3 (DV). Imported with a PAL 4:3 recorded footage via firewire & save my edius project & exit edius.
Upon restarting edius 3.62, by clicking the a/m project name, I encountered the following errors;
i) 'Hardware Error! - Are you sure you want to change project settings? Yes or No ?'.
ia) If YES -> I would be able go into my edius project BUT having this error;
'The selected CODEC can not be used in this system. Please select to a different CODEC in the project setting dialog' -> when click OK, the project file opened BUT the system seems to be in NTSC & the Aspect ratio changed to 16:9 or widescreen instaed of 4:3 PAL when originally selected before i started this project.
A printscreen sample of the 'Funny Widescreen' aspect ratio under my Preview Monitor which previously was saved in PAL 4:3 before quitting edius is as follows;
I tried verified this current project settings & found that under OUTPUT device, I justified that its NTSC because ;
This NTSC OUTPUT DEVICE settings displayed its equivalent settings for me to choose from whilst under the PAL selection;
No selections can be found. Thus, Im convinced that this project is in NTSC rather than in PAL which i started off with.
Upon encoding & exporting such project into DVD, the playback aspect ratio were much smaller than 4:3 or even 16:9. Perhaps like 640 x 480 pixels etc.
ib) If NO -> I would experienced 'Can't open file ! - 'The video standard does not match the current settings'. -> when click OK, 'An unexpected error occured while reading f:\xxx\xxx.epj'.
My main query is since my Edius + NX card were set to PAL system via DVCapture ver1.11 (since edius 3.62 don't have PAL/NTSC system selection for me) & I verified that the project saved is in PAL (under NX-E1 or OHCI) settings, WHY would I still received such 'Hardware Error'???
The CODEC used is DV AVI Exporter.
Could it be really my NX hardware problems or just some CODEC issues ? I really can't afford to have my aspect ratio changed by itself if only I need 4:3 or 16:9 under DV codecs.
Could it be that the edius 3.62 is incompatible with NX(PCi-X) card (which i doubt so as many ppl have proved it working fine thus far) ?
Or could there be any settings that I maight have missed out during installations?
Im glad to know that when i chose OHCI project settings -> DV PAL 4:3, 48k -> Re-capture the PAL DV footage via firewire ->do some edits -> finally toast to DVD, the PAL 4:3 apect ratio stays.........
It makes me feels that my NX card really have problems after having tried the a/m OHCI project settings.
BTW, I had done a CLEAN re-installation + a FULL re-format of my system once each session but the error still persists !
Can anyone advice if you had ever encounter such issues before with NX card ??
Thanks All for Viewing..
